★the problem about i3d cloud . HELP!★
jack5302003
hey guys I want to make cloud use i3d. I did cloud use vex meta cloud before . so this time i want
to use vex fluffy cloud as i3d shader . I Created particle system and add noise to it. then choose one
frame to render.the rendered result too bad. the cloud too little. so I adjust the cloud radius of
vex fluffy cloud then render. this time the result better. more details. but it looks like the sphere
cloud or volume ball . it is very different from my particle. my particle looks like the cloud in
sky. but the rendered picture too bad. vex meta cloud is ok. the file size is 1.0M ,but vex fluffy
cloud just 57K . I tried to fix the problem but still is . hey guys what shall i do ? how to fix
it ?please forgive me my english.^_^
cheers
thank you sea. I understand what you said . first creat the particle system then copy metaball to pop. then use shader to render.thank you . My particles looks like cloud or smoke ,but why rendered picture looks like sphere cloud or volume ball? I want to know why. I don't understand. Maybe because the vex fluffy cloud ?
