changing rbd pin constraint pivots
terze
The information you're looking for can be found in the Handles Online Help page.
Start the Houdini Help browser & copy-paste this: http://localhost:48626/basics/handles
You can also search for "Pivot" in the Help browser.
Cheers!
steven
I suppose terze meant the anchor of constraint at the constrained object's side, which by default is at the center of that object. To move it freely at any point or primitive of the object, open RBD Pin Constraint for editing, jump inside and replace Anchor Object Space Position DOP with Anchor Object Point/Prim Number Position DOP (Constraint tool TAB submenu). This should work. In case hard constraint won't work, do the same with spring constraint initializing rest length with correct distance between two constraint's anchors.
hope tha helps!
cheer!
skk.
