Pcwrite to make sss pointcloud
Korhon
Hi!
I was wondering if its possible to use pcwrite to write out a pointcloud that Houdini`s SSS shaders can use?
Im guessing i need to write a ptarea atribute like the sss_scatter Sop does, but i dont know how to that with pcwrite :)
Anyone that know how to do this? :)
Thanks!
i'm sorry, i did not quite understand the question..
do you intend to write the Point Cloud data to disk?
(if yes..you can write it out with a normal File SOP with a .pc extension while saving....you can access these in VEX using the pointcloudopen vop)
I guess ptarea is a promoted attribute..you basically calculate area of a primitive (or your geometry) and then promote it...you can dive into the SSS Scatter node to see how its done.
hope this helps.
Thanks for the reply!!
Yes i want to write pointcloud to disk. But i want to do it with a shader. ( the pcwrite node)
That way its easier to write pointclouds that can be displaced.
The scatter sop uses the measure node to create the area atribute it seem.
And i dont know how to do this in vops :(
Anyone? :)
Anyone? :)
There is a function in VEX called area() (and corresponding Shading Area VOP), which does similar thing. Few questions arise though:
a) Does ScatterSOP, which computes ptarea for SSS Scater by averaging distance to neighboring points, takes a power of it or not?
B) SSS Scatter seems to weight ptarea with average area for a whole geometry (ptarea * (ptarea/total_ptarea) ). How to achieve similar thing in vex?
c) Quite possible you don't want to save every micro-polygon in point cloud, how to sum up areas of points left behind (not saved in point cloud)?
Thanks Symek!!
I will look into the Shading Area Vop, and see if i can make some use of it :)
To get a pointcloud that don`t contains every micropolygon point i was hoping there was a way to control the shadingrate with the shader.
