Guest Swann Posted August 27, 2009 Share Posted August 27, 2009 Hi, Just switched to new Houdini build and I got those messages. It looks that everything works but who knows. What they mean ? Quote Link to comment Share on other sites More sharing options...
graham Posted August 27, 2009 Share Posted August 27, 2009 (edited) I've seen this happen recently were a file from a newer build of Houdini 10, 369, was loaded in an older build, 295. I believe the newer build of Houdini had some under the hood changes to make it more compatible with a new feature in a future version and that is why this error happens. Opening the hip file in the newer build there was no error. Edited August 27, 2009 by graham Quote Link to comment Share on other sites More sharing options...
Guest Swann Posted August 27, 2009 Share Posted August 27, 2009 (edited) In my case it pops up when I open it in newer version. Another thing that I noticed is that when in turn on Parameter View( key P) in Network View after some it time blocks. Houdini works normally. I can change parameters in parameter Tab that is turned in another window but to get working this in Network View I have to restart Houdini. If you try to press P to turn it off and then turn it On it shows up blank. Anybody else have this problems ? I have this on build 373 and 379. Edited August 27, 2009 by SWANN Quote Link to comment Share on other sites More sharing options...
edward Posted August 28, 2009 Share Posted August 28, 2009 These flags were introduced into the H10.0 baseline for a bit and then subsequently removed again. So if you have a build producing them, you should be able to save in the latest daily build to remove them. Quote Link to comment Share on other sites More sharing options...
