win32 binary
eloop
Hi guys,
Here is a new win32 version to test ...
hotbin_win32_H10.0.374.zip
The easiest way to install is to setup the following two env vars (See My Computer>Properties>Advanced>Environment Variables). I'm assuming you've unzipped directly into the c: directory, you'll need to modify the following accordingly.
HOUDINI_PATH c:/hotbin_win32_H10.0.374;&
PATH c:/hotbin_win32_H10.0.374/dlls
Note: Don't nuke your PATH if it already exists, add the above entry with a ";" between the entries. Example files are included in the archive, they should all work. Please post your experiences (yay or nay) in this thread.
-Drew
