itriix Posted August 31, 2009 Share Posted August 31, 2009 (edited) how's it going? so i have a question about setting up an expression in my mantra rop out pic field. What I want to do is use the $HIPNAME variable to help construct what I want the file out name to be... however, I want to remove the '.hip' part of the filename... example: $HIPNAME = awesome.hip in my output pic, if i had the path set up, and used $HIPNAME as the "name of the file" then the name would be awesome.hip.$F4.tif instead of awesome.$F4.tif.... i was going to use python's string editing abilities to remove the last 4 characters but, couldn't seem to use the $HIPNAME variable when I was using python. I tried to look for a python-->hscript command that could use those variables but only noticed some python --> hscript functions instead of that. thoughts anyone? thanks a lot Jonathan Edited August 31, 2009 by itriix Quote Link to comment Share on other sites More sharing options...
edward Posted August 31, 2009 Share Posted August 31, 2009 I do this for my render drivers: $HIPNAME:r.$F4.pic Quote Link to comment Share on other sites More sharing options...
itriix Posted August 31, 2009 Author Share Posted August 31, 2009 (edited) and one more thing, what is wrong with this expression? $HIP/renders/$HIPNAME.$F4.tif in the output picture of the mantra nod FIXED: it wasn't rendering because i had the wrong path to the camera oh well, was my first attempt at making a camera and light set up as an HDA Edited August 31, 2009 by itriix Quote Link to comment Share on other sites More sharing options...
itriix Posted August 31, 2009 Author Share Posted August 31, 2009 (edited) I do this for my render drivers: $HIPNAME:r.$F4.pic alright cool thanks! i'm aware of this notation when referring to objects in networks, and also in python as slicing.... just not sure what it's doing in this example... $HIPNAME:r.$F4.pic BTW it works fantastic tho thanks again Jonathan Edited August 31, 2009 by itriix Quote Link to comment Share on other sites More sharing options...
edward Posted August 31, 2009 Share Posted August 31, 2009 Actually, the ":r" is called a "variable modifier" which is a feature borrowed from csh (eg. http://tomecat.com/j...tt/cshvars.html) http://www.sidefx.com/docs/houdini10.0/commands/_guide Quote Link to comment Share on other sites More sharing options...
itriix Posted August 31, 2009 Author Share Posted August 31, 2009 (edited) Actually, the ":r" is called a "variable modifier" which is a feature borrowed from csh (eg. http://tomecat.com/j...tt/cshvars.html) http://www.sidefx.co...commands/_guide thanks so much. i really appreciate your help Jonathan Edited August 31, 2009 by itriix Quote Link to comment Share on other sites More sharing options...
