Fur Base Opacity n Tip opacity controls? where are they?
kensonuken
Where is base opacity and tip opacity controls in Houdini fur?
Your furs will have nice normalized parametric coordinates - s and t. This means that s and t will go from zero to one across the length and width of your fur ribbon. You can use this to drive opacity.
And that is exactly what the fur material is doing.
Have a look at the Opacity ramp. You can control the opacity of the fur here. Opacity supports color information as well so you can tint the transparency to affect the final color of the fur. Left is root, right is tip.
