how to setenv to my hip file that is opened
kensonuken
I want to put the hip file in a location
and want to render out all the files according to the following
character\mesh\shadowmaps
character\mesh\beauty_renders
but I want to put my scene files in some other folder by name hip and im thinking to put the entire folder structure like
hip ( where i put the hip files )
ren ( where I want to put the rendered files)
geom ( geometry files )
ifd ( render scripts ) etc etc...
like this I would like to put the structure... can anybody guide me how to do this?
I want to setmy env to the current hip file where ever it is stored or moved... how to do this?
Im a little confused about the details of what you are attempting, but maybe this will help some....
$HIP will give you the path to the current .hip file and $HIPNAME will return the file name incuding ".hip" extension. These can be used individually or combined to set a variable containin the full file path.
Within houdini you can always use relative paths too when pointing to outside folder/files if they maintain a consistant directory structure...
Hope it helps
