problem with hscript rendering
MrGAG
Hello,
I am trying to render a hip file using command line.
I do it this way :
in a hscript command prompt :
  mread c:/my_scene.hip
  cd /out
  render mantra1
it works but when I want to define a frame range, it doesnt work anymore, I can't define a frame increment either.
when typing
 render help
it shows me all the options for the "render" command. But none of them seems to work; basically it doesn't seem to take into account options I feed into command, it takes only the parameters in my rop node.
What am I doing wrong ?
  On 9/2/2009 at 2:51 PM, MrGAG said:
when typing
 render help
From the help
     -f
          Override the frame range to render. This range will be
          trimmed to the ROP's frame range (if set). If 'Use Frame
          Range' is off, this range will be used.
Maybe you have "Use Frame Range" turned on?
