noise using VEX and for loop
bhaveshpandey
I'm trying to write a VEX script which would apply noise to a geometry using a for loop..(I'm a newbie in VEX so please excuse my lack of knowledge :) )
basically what I intend to do is to Layer the noise affecting a geometry using its Point numbers as counters in the FOR loop and multiplying it with a Amplitude gain and Frequency gain parameter so that its increasing/decreasing for every iteration (which would thus give me good layer of noise applied on top of each other to a geometry.
here's the scrip so far:
float amp, freq, again, fgain, sum;
int i;
for(i=0; i<npts; i++)
		float noise;
		float AMP;
		float FREQ;
		float AMP= amp*again;
		float FREQ=freq*fgain;
		noise= AMP* noise(FREQ*P);
		sum+= noise;
Sop
Sop1(amp=0.5, freq=2, again=o.5, fgain=0.5)
sum;
I have declared the variables etc..but i'm getting a syntax error in the first line..but I cant see anything wrong with it??
Also I'm not sure of how to execute it in the sop level...so just to check I just called it in the SOP level..but I'm not really sure about it....
could someone help me with this..
Thanks.
PS: here's a .vfl file
Edited by bhaveshpandey
There are quite a few things wrong with your vex code.
Try this:
//pragmas for your parameters
#pragma hint again hidden
#pragma hint fgain hidden
//if you like to use some custom functions put them here
//the very body of the sop
Sop
Sop1(float amp=0.5, freq=2, again=0.5, fgain=0.5;) // your user parameters.
vector PP; //temporary P
float mynoise=0, sum=0;
int i;
for(i=0; i<Npt; i++)
        mynoise= amp* noise(freq*P);
        sum = mynoise;
PP = set(P.x, P.y+sum, P.z);
//do something to attributes to see the result:)
P = PP;
Have a look at houdini help, it's very good.
Edited by peliosis
