how can I source my own expression
kuaile_yzh
eg: there is a fuction
float bias(float b, float x)
{ return pow(x, log(B)/log(0.5)); }
saved as bias.h
when I enter houdini, from the edit menu
open aliases and expressions menu
Load Expresssions File hit Load Expressions file and load " bias.h"
Every time I have to redo these steps in Houdini, is it possible let Houdini auto load it?
how can I source my own expression in Houdini, so I do not need to reload it at each time when Houdini is opened.
You need to put a command:
exread bias.h
into your 123.cmd or 456.cmd files (not sure if 123.py... will work too, but it should).
