emit particule from texture
Spyrogif
here there,
i'm new at houdini and concentrate actually on particles.
Did you have any idea how i can control particules emitting with a texture.
I've understood the color to particules via pic() fonction but it's not what i need.
My goal is to create a grid who emits only where my texture is white (this is a black and white texture).
Of course i can plug my color informations to particules alpha with the pic fonction but it means unwanted compute time with the non alpha particules.
How can i send the pic() values into the Const birth rate of my source node ? (something like black=zero emitting white= Const birth rate value.
If you have any idea to help me :rolleyes:
btw : Sorry for my bad english, i do my best !
what is the best way to replace the brush node by a texture ?
in the http://www.sidefx.co...1030&Itemid=216 the brush node override color and create a area attribute who is use by the scatter.
i'm not comfortable with attributes how can i tranform my Cd attribute to a area attributes ?
Edited by ndeewolfwood
ok i've found a solution mixing different techniques found in older post. and it's good to go :-)
i start with my object> a uv node>a subdivide to get fine distribution>a VOPSOP to get the cd attribute (damnn it's so quick compare to pic() fonction)>a pop net
in the pop net i put a $Cr in the birth probability...and voila...
first time using the vopsop :whaaoo it's really cool and simple.
