Carving Multiple Curves By attribute (HIP file attached)
Hey guys!
I have a bunch of hair strands here, they each have a PRIM attribute "dist" that is the distance from the center of the hair bunch between 0-1.
i would like to carve each curve by the dist attribute.
I have successfully accomplished this in the hip file, but i used a foreach node, which is way too slow for my taste, anyone have a faster way of doing this pleaaase? It's slowing my hair node by 100%
H13
dropbox, and attached
https://www.dropbox.com/s/phb074flfkdp4gy/carve_help.hip
carve_help.hipFetching info...
I don't think you can do that because Carve SOP doesn't support $PR or any custom variable unfortunately. I think it's designed to carve geometry at once using the same settings. Consider submitting an RFE to SESI so they could implement it :)
daaamn okay. Yes i noticed it doesn't support custom local variables, would be nice! I posted it up on sidefx forums.
I tried doing it by deleting points, but i didnt get such a nice interpolated result that you can get with Carve or extreme amount of points.
edit: what's an RFE?
Edited by Vivi
It's basically Request For Enhancement, that you can submit from here:
http://www.sidefx.com/index.php?option=com_content&task=view&id=768&Itemid=239
Someone might come up with a different approach. I think you could resample and then delete, and then convert them back to NURBS if they were NURBS, but that would also increase cooking time.
  • 1 year later...
There is a method here using a attribWrangle:
Workflow is basically to basically create new geo on top of the old geo.  Sample the points from the old prims, and rebuild new prims but using an attribute to drive how far along the UV direction of the curve, then delete the old prims.
  • 1 year later...
  On 7/13/2015 at 10:14 PM, mawi said:
Try this...
Put down a measure SOP and set it to measure the perimeter of your curves.
After that a primitive wrangle and write.
#include <groom.h>
adjustPrimLength(0, @primnum, @perimeter, @perimeter*@dist);
groom.h is a included file containing some functions used in the grooming tools and one of the functions is...
void adjustPrimLength(const int geo, prim; const float currentlength, targetlength)
Expand
Really Cool technic ! Thanks so much!
  • Like 2
  • 8 months later...
