Fire Flipbook Loop
blendingshadow
Hey,
I was wondering if there is a better way to approach creating a looping flipbook fire?
Peter Quint has a great tutorial on using time shift to create a loop but it looks like it's cross fading.
Could something be done at the comp level, ie: rendering out 'x' number of frames, finding similar frames?
Or is there something you can do with the volume data to make it look the same at a user defined frame.
Thanks
Don't you need to some drive the fields back towards a target "state" at a particular frame? Offhand, I don't know how one would do that but I can't imagine getting (remotely?) good results otherwise without cross fading.
