[SOLVED]A Pulse With Decay?
Atom
Hi All,
I am looking for a python or Houdini function that will give me a pulse to 1.0 with a decay every so many frames. So it would kind of be like a modulus integrated with a decay. Does anyone know how to code something like this?
A typical output might look like this...
0.0 0.0 0.0 0.0 0.0 1.0 0.8 0.6 0.4 0.2 0.0 0.0 0.0 0.0
Edited by Atom
My goal is control the eye blink on a character.
The ramp is an interesting idea, but I still need to feed it a lookup value between 0.0 and 1.0 which needs to be the percentage along the modulus of the blink rate in frames.
node = hou.pwd()
geo = node.geometry()
my_ramp = node.parm("ramp").eval()
n = my_ramp.lookup(0.5)
print n
I guess with a little fixup I think this kind of approach works and I can still use the ramp for shaping the decay of the eye blink.
node = hou.pwd()
def returnFramesPastLastModulus(current_frame, current_modulus):
    cf = current_frame
    while(cf > current_modulus): cf -=current_modulus
    return cf
frame_current = hou.frame()
blink_rate = 120    #Blink every 120 frames.
f = returnFramesPastLastModulus(frame_current, blink_rate)
v = float(f)/float(blink_rate)
n = my_ramp.lookup(v)
print n
Thanks for the insight.
Edited by Atom
