(novice) Drip Particle Fluid isn't colliding with the ground plane
I have been playing around with Houdini for a few months now and have now got stuck into 16.
As the title says, the new drip particle fluid node doesn't enable it to collide with the ground plane (see attached hip file)
How can I make it collide?
blood.hipnc
dunno what you did but there's no Groundplane in your Dripfllip sim. All I did is delete your current groundplane, re-addded from the shelf, and it added the Groundplane/Static solver to the Drip sim......works fine...
