(novice) parameter or syntax that returns the name of the current parent node
I'm sure I've come across the answer before but have googled quite a bit and searched thru the documentation and can't find anything
What is the parameter or syntax that returns the name of the current parent node?
ie
In the following I need to replace <name of parent node> with a variable  that actually returns the parent node's name. I assume it begins with $
$HIP/../obj/LowPoly_leaves_pack/Textures/<name of parent node>/<name of parent node>_DIFF.png
Thanks!  Surprised there doesn't seem to be an HScript global that does this like $OS for the current node name, Would be extremely useful why applying custom shaders to many objects, for example
Edited by art3mis
