Hello.
I can't find solution with creation dirt from wheel.
For now i created sticking particles to the wheel.
The problem is when sticked particles have to fall they started emitting every frame.
I need only existing point to stick and then fall off.
Thanks.
Edited by alex333d
Share this post
Link to post
Hello alex333d,
    I had quite a similar task to do, I ended up using a sop solver for activating the particles that needs to fall off.
- Basically you can scatter your points on your wheel on a static frame and then you can use a point deform to make them stick to the animation.
- Once you have those animated points you can feed them into a SOP solver and give them a custom attribute when a certain condition triggers it (you can for example use a dot product with the wheel's direction as a threshold) and register if this is the first time it is activated or not.
- Then you just need to isolate those activated points to feed them to DOPs.
I am not sure if I am completely clear in my explanation, if you are interested, if I have some time in the evening I can to a quick .hip file with the setup.
Hope this helps!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
