Parent as Selected
CinnamonMetal
parent = thisNode.parent()
if parent:
   parent.setSelected(True)
Checking if parent exists in your code makes me suspicious about your goal though. Are you actually interested in hierarchy selection or network selection? Above code returns a network which contains a node: so for /obj/geo1 it will return /obj. For the ancestors nodes you have to use parents = thisNode.inputs()
I wanted the hierarchy selection.  ^_^
inputs() retrieves the the parent node, which I thought was the node above, the PythonSOP.  The parent node is the first node in the hierarchy.
How do I get the node which in this case is the node one up before the PythonSOP ? As well setInput() doesn't accept index number ?
Edited by CinnamonMetal
