alembic file - how to isolate elements
Hi guys,
I have an alembic file with lots of elements and I am trying to isolate the one by one by blasting points.I would help if delete points with the bounding box to find out what points (initial point number) I was deleting.How can I see initial point number which was deleted by a bounding box?
TKS.
here, try this...(it's isolating by vis...so keeping point numbers)
you can go into the iso group, move the bbox around to see effect
(note the convert, even tho i already said unpack in the alembic node, you still need the convert for the geo to be 'kosher')
EDIT: oops forgot the boxes...here they are
testboxes.hipnc
boxes.abc
Edited by Noobini
