follow path question
dan_j
i usually do it with linking the transform sop to the NullObject which is following te path at obj level
just link each parameter (SRT) using origin() expression to get a global transform of the null
like origin("","../../null1","TX") ... (TY, TZ, RX, RY, RZ, SX,...)
maybe it can be done easier and more elegant
for entire sop solution you can also take a look at carve sop, plug your curve in, change to extract mode, copy your object onto it and animate the first U parameter
however you wont get rotation this way
