bhaveshpandey Posted October 9, 2009 Share Posted October 9, 2009 (edited) I have a stupid issue at hand which is starting to bug me.... After lots of hard work I was able to install Realflow on Ubuntu 9.04 but I'm unable to navigate the viewports as pressing the Alt key and moving the mouse moves the whole realflow application's window with it. I had similar issues with Nuke before due to which I kept working on Nuke in Windows.. Has anyone else faced similar issues?? Any suggestions to get around it?? cheers. EDIT: Although if I use CTRL+ALT+ LMB I'm able to orbit around in the perspective view..however the same combination doesnt work for zooming and tracking.. Edited October 9, 2009 by bhaveshpandey Quote Link to comment Share on other sites More sharing options...
vmuriel Posted October 10, 2009 Share Posted October 10, 2009 Change that Gnome behavior at Windows Settings panel. Quote Link to comment Share on other sites More sharing options...
postezz Posted October 11, 2009 Share Posted October 11, 2009 if you are using kde you should change the modifier key- the setting is located at system settings>Window behavior>window actions> , by default it uses the Alt key Quote Link to comment Share on other sites More sharing options...
