ddintz Posted October 11, 2009 Share Posted October 11, 2009 i have a maya camera animation that i need to get into houdini. i have researched it, and there is talk about a 'chandump mel script' that needs to be used to get export the channels out of maya. the link to the script points here, but it is broken. http://www.odforce.net/downloads/tools/chandump.mel is there a new way of doing this? the info i have is about 5 years old. thanks for the help, d Quote Link to comment Share on other sites More sharing options...
carstenkolve Posted October 11, 2009 Share Posted October 11, 2009 Export camera to FBX in Maya, then import it into Houdini, works pretty good I found. Cheers, Carsten i have a maya camera animation that i need to get into houdini. i have researched it, and there is talk about a 'chandump mel script' that needs to be used to get export the channels out of maya. the link to the script points here, but it is broken. http://www.odforce.net/downloads/tools/chandump.mel is there a new way of doing this? the info i have is about 5 years old. thanks for the help, d Quote Link to comment Share on other sites More sharing options...
symek Posted October 11, 2009 Share Posted October 11, 2009 If for some reason Fbx doesn't work for you, you can check some other options like this recently posted: http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=16719&highlight=maya++houdini+camera Quote Link to comment Share on other sites More sharing options...
mangi Posted October 12, 2009 Share Posted October 12, 2009 Hi there, I do not use maya. at the job we use xsi, I did some cam export back and forth , the best was collada. you only hade to make a small adjustment in the field of view FOV, manually , but it was the only way I got it working correctly. I am sure collada is in maya, Its really cool when you finally get it working Mangi at pocoyo.com Quote Link to comment Share on other sites More sharing options...
