Baking an object sequence to single object
Farsheed Ashouri
Hi folks. First I need to know is it possible to bake an object sequence to single one? ( like keyframing vertexes or something else )
And If the answer is yes, could anyone please help me to develop a little ( or Big!!! ) tool for this purpose?
For sample data, I prepare a simple 24 frame sequence. test_sequence.tar.gz
Thank you in advanced.
Easiest way would be chops, load the animated geometry into chops and lock the read node. then transfere it to sop again. but if You need a export to another software, I would use mdd files. there are plugins for maya, and xsi has a build in version
There is an helpcard example for the MDD SOP as well if you look in the online help.
Well, Thanks. I think i have solved the problem using tail sop, (witch add motion blur to the sequence):rolleyes:
Thanks again for your help.
EDIT: Wow Edward, your post changed my life. with .mdd format, now i load my scenes 10 times faster. Cheers.
Edited by Farsheed Ashouri
