creating a noise spectrum VOP
The variables inside the For loop are prefixed with an underscore (to differentiate from the values outside the loop), you need to use the underscores in your inline VOP.
$noise = $_amplitude * noise($_frequency * $_P);
Also, not fatal, but the inputs to the Inline VOP and the For loop seemed to have gone out of sync (the extra _next variable), so I rewired the Inline VOP
As an extra tip, I'd recommend using parameters instead of constants for the amplitude and frequency to make them easier to adjust outside the VOPSOP.
On the same note, I'd make a new parameter called something like "octaves" and connect it to the "end" input of the For loop.
eetu.
creating_noise_function_v04.hipnc
