reflection antialiasing
hello i have problem with reflection antialiasing, micropolygonal render, more samples dont work for me...
look at the picture, standart chrome, old good debevec hdri UZIFI. If I turn off reflection, antialiasing is good on 4*4 samples. I try 10*10 but reflection is still bad. Is there something I miss in render settings? I try other filters but no change. Thanks a lot BC.
Great, only thing, colour limit in mantra, do you mean ...
Mantra ROP -> Gear -> Edit Rendering Parameters -> Mantra 10.0 -> Render -> Color Limit (vm_colorlimit)
Drag this to add it to your Mantra ROP parameters in the middle of the window.
Set the value of the parameter to something a bit over 1.
eetu.
  • 2 weeks later...
Hello again
Im trying to add parameter to mantra render node, color limit, but default value is 1024. Eetu write that value little bit more than one helps. I now render some liquid tests with some HDRi and I have same problerm with bright pixels in reflection. I try a lot of different values (.001,.01,10,100,4000), but almost no changes. DoI something wrong?
