how can I kill the overlayed particles
1. create a source of particle, create 10 particles at first frame, the speed is 1.
2. create a split node, which create particles from the original particle, the speed is 0;
so the result is 10 particle lines.
problem is , 20 particles are overlayed each other. how can I kill the overlayed particles?
howtokill.hipnc
actually I want to do the effect that if particles get close to each other to a certain distance, they get killed. like the image below.
but I can't get the id of the original particle.
houtokill2.hipnc
I'm thinking if the overlayed particles created by split node could be killed, the problem might be solved.
If I understand you correctly, then it's just a matter of grouping everything. Just set up groups for each change. I've included your file where I made sure to give the split group and the overlay groups their own group names.
HTH
houtokill3.hipnc
