CSN0309 Posted December 4, 2009 Share Posted December 4, 2009 Hi~ guys now i got a problem, i have written a custom displacement node in VEX networks, then i import it into the SHOP network and connect it to suboutput node. When i get the result of my scene by mantra, i was puzzled, there is no shading and lighting effects on my scene, but i did put a distant light in my scene and pointed to the object, and i did set up the light linker to connect the light and object. so~ why?? Thank you! Quote Link to comment Share on other sites More sharing options...
Ratman Posted December 4, 2009 Share Posted December 4, 2009 Not a whole lot of info to go by, but do you have a lighting model vop in your surface shader? Quote Link to comment Share on other sites More sharing options...
CSN0309 Posted December 4, 2009 Author Share Posted December 4, 2009 (edited) yes~ i put a lighting model in my surface shader. now the problem is when i disconnect the displacement node, the lighting effects comes back, but if i connect the displacement node into the suboutput node, the lighting effect disappear... Edited December 4, 2009 by CSN0309 Quote Link to comment Share on other sites More sharing options...
TheAdmira1 Posted December 16, 2009 Share Posted December 16, 2009 can you upload your example? I dont really understand what you're asking? I see the lighting effects in both scenes? the only difference is that the Displacement made an ocean like ripple on the surface so the lights are reflecting off the ridges? TIA Quote Link to comment Share on other sites More sharing options...
