Isolate area for smooth falloff w fractal sop
magi
Hello!
I could use some help to figure out how to get a smooth falloff for an effect. I have grid and i have fractal sop. I want to paint an area where the intensity of the fractal sop is much less than applied to the rest of the grid. How I can do this?
I make a test with a grid, grouppaint and fractal sop but not sure how I can soften the fractal effect on the painted points?
Thank for help
You need a full Paint SOP so that you can feather in the effect.
hi thank you for file. May I ask why rest of grid not have fractal?
I was looking to have low setting in painted area and high freq setting in unpainted area.
sorry if i not clear
Edited by magi
He is using the color to set frequency of the noise. If the color is black, ie 0, then there will not be noise. White, ie 1, will give a freq of 1, and everything in between. So if you want areas to have noise, you can paint that the value you want to set.
