(Entropy + Houdini) Post-include for AreaLight set
(sorry for my poor english)
I'm setting an areaLight and having trouble post-including.
A sample declaration for an area light source is shown below: (exerpts from techref.pdf for entropy)
AttributeBegin
Attribute "light" "nsamples" [16]
AreaLightSource "arealight" 1 "intensity" [30]
"string shadowname" ["shadow"] "float shadowbias" [.15]
#above 3 lines are pre-included okay.
Translate 4 2 4
Rotate 90 1 0 0
Rotate 60 0 1 0
Rotate -20 1 0 0
Scale 1.5 1.5 1.5
Surface "constant"
Patch "bilinear" "P" [-1 1 0 1 1 0 -1 -1 0 1 -1 0]
AttributeEnd
Illuminate 1 1
# But above 1 line is resisting Post-included.
First part is pre-including okay. But the second part is not working.
So I had to include "Illuminate 1 1" by hand.
I think geo tile's post-include is not working at all. Cam or light's post-include is working properly, but it doesn't do the trick for areaLight setting.
What is the proper way to include the "Illuminate 1 1" ?
Thanks for advance :)
Hmm... Looks like it's a lot more complicated than I thought. :( I am not certian how to automatically change the LightSource into AreaLightSource. If this is SOP, we *might* be able to use Attribute or Attribute Create SOP to change things around.
Welp, I guess we'll have to wait or Jason or someone else who knows.
Just wait a bit longer for everyone to get back from Siggie.
the arealight shader, the geometry, and the illuminate statement go before the world begin.
I made an object subnet, all the geometry you put into the subnet gets turned into an include rib.
There's the the subnet.ds, a couple of command files, and a perl script that cleans up the .rib file.
It dumps out your lights and area light geometry into a .rib, mulches it into a useable form with the perl script,
then sets up a light source to use this include .rib at the beginning of your rib files, with area lights.
The gzipped tar file is 2.6k, I can e-mail it to you if you want it. It's less than perfect, I was going to clean it up
and put it on odforce, but with recent developments, there's sort of no point. :( If you want any of it, just e-mail me.
ivan@hero.com
