impatct data on inactive objects?
sanostol
Inactive objects are naturally inactive (not being simulated), so they don't know anything about objects colliding with them or anything else in the system. You'll have to look at your active objects that are impacting and then checking against the otherobjid field to see what objects your active ones are impacting and then activate them.
Edited by graham
is there a way to get impact data on inactive rbdojects. for example i want objects only to be active if they get hit by something. right now I don't get the impacts
Martin
You could stop overwriting their position once they got hit, thus keeping them all active, but without side effects result like moving them ;). But this is not an answer if you're trying optimise simulation this way?
cheers,
skk.
ps Actually doesn't AutoFreeze DOP work this way? Doesn't it allow object to melt and go back to sim after being disabled?
  • 1 year later...
