Coloermap and Vertex Uvs do not work together?
sanostol
I have a object with vertex uvs (obj import). now I want to use a vopsop to assign a color to each point according a image and the uvdata, but the result looks more than strange.
I tried a simple setup with pointuvs and it works, the vertex also fails on the grid, but I can assing the color using the tex() expression in a pointsop, though. so My question is why does the vopsop fail, when the expression does not?
I attache a example scene
thanks a lot
Martin
color2points.hipnc
In your example, switching to point Group Type in the uvproject2 node seems to work, no? Is this what you want?
well, but switching to point mode in a loaded geometry with uv coordinates is not possible
another thing is that the pattern changes everytime You load the scene :blink:
Edited by sanostol
  • 2 weeks later...
