how can be done these effects??
dyei nightmare
hi, everybody, im learning houdini actually, im comming from maya, and i just wanna know how do you achieve these kind of effects in houdini, if someone could give an example...
the first is this formation of adidas logo made with instanced cubes, and the name made with instanced cubes too:
and the other is this effect where the cubes and the walls are ramdomly extruded or moved in normal directions in random blocks following the rithm.
Edited by dyei nightmare
The second one was done as a group project at Bournemouth University as a student project , as far as I remember they heavily used Chops for this project and particles, but may be you should try contacting Coen Kloster on this forum and he will be able to tell you the exact technique.
or you can go here and read this blog for it : http://connexmade.blogspot.com/
Edited by zasid
