fill hole
imoh3n
Hi, i switch from Maya to Houdini.
but i have a problem for fill holes in my objects, Maya have a fill hole command that work very good, but in Houdini i can't find situation.
I hope if anybody can help me.
Polycap is what you are after. But before it can be used you have to create a group with Edges and unshared edges active (Entity: Primitives and disable number). After that point the polycap to the new group and it should work.
Edited by wigal123
It usually works with me if I first select an edge using the Select tool and then apply the PolyCap ... ie. without needing an extra Group SOP.
  • 6 months later...
