Initial velocity to an object in volume fluids
Hi Guys.
I'm suupernew to Houdini, and so far I think it´s amazing (coming from Maya/3Ds MAX/RealFlow/Nuke etc).
I was wondering how you would go about to get a initial velocity to an fluid created from an object in volume fluids?
Also, is there a way to control where the fluid starts on an object? I know in Maya I would mask it with an ramp to tell it where to start?
Thanks in advance
//Anders
Yep. I will do that.
My first post here.. But will do that for shure.
And, tried it and it worked like a charm with the velocity.
I'm sitting and screaming of joy working with Houdini (when I'm not tearing the little hair I have left 'cause I'm used to different software)
In the attached hip file by mawi, either keyframe or use an expression, for example, $FF < 3, in the Activation parameter of the sphere_object1_source DOP.
This will set the sphere_object1 DOP object as a source for only one frame or in other words, set the Source Relationship for one frame then turn it off.
Cheers!
steven
