Houdini Fur shader mod to Kajiya Kay
kensonuken
I was just checking the code of Houdini Fur shader which was not kajiya kay... Is there any possibility where we can use kajiya kay shader in Houdini? or can we modify the current kajiya kay shader to Houdini shader?
here is the prman code that I have .
// based on ATI's paper 'Hair Rendering and Shading', by Thorsten Scheuermann //
// 3D application research group, ATI research Inc. ////////////////////////////
// this is a hair rendering technique originally made for polygon hair models //
// a mix of Kajiya-Kay hair shader model, and Marscher's model, presented at //
// Siggraph2003 ////////////////////////////////////////////////////////////////
// shifting specular highlights along lenght of hair
vector shifttangent(
vector Tn;
normal Nf;
float shift;
vector shiftedt = Tn + shift * Nf;
return normalize(shiftedt);
/* Specular strand lighting */
float strandspecular(
vector Tn, Vn, Ln;
float exponent;
vector Hn = normalize(Ln + Vn);
float dotth = Tn.Hn;
float sinth = max( 0.0, sqrt( 1.0 - dotth * dotth ) );
float diratten = smoothstep(-1.0, 0.0, dotth);
return diratten * pow( sinth, exponent);
/* Main */
surface tshair(
//color tshair(
float Ka, Kd, Ks; //ambient, diffuse, specular coefficients
float shift; // primary specular highlight shift
float shift2; // secondary specular highlight shift
float exponent; // primary specular exponent
float exponent2; // secondary specular exponenet
float specmask; // specular mask, to shift secondary spec
color Cdiff; // surface color,sometimes bound to geo
color Cbase; // hair base color
color Ctip; // hair tip color
color Cspec; // primary specular color
color Cspec2; // secondary specular color
normal Nn; // normal vector
vector Vf; // viewer vector
/* We're going to need dPdv for direction, P for the illuminance
* construct, and the v coordinate for the color blend in the color
* contribution. */
extern vector dPdv;
extern point P;
extern float v;
vector T = normalize(dPdv);
normal Nf = faceforward( Nn, Vf );
vector t1 = shifttangent( T, Nf, shift - .5);
vector t2 = shifttangent( T, Nf, shift2 - .5);
float dottin = T.Vf;
color Cdd = 0;
color Css = 0;
illuminance( P, Nf, PI/2 )
extern vector L;
extern color Cl;
vector Ln = normalize(L);
uniform float nondiff = 0;
lightsource("__nondiffuse", nondiff);
if (nondiff < 1) {
/* Scaled diffuse term. Note that in the paper they use
* ambient occlusion to fake the hair shadowing. */
Cdd = clamp( mix( .25, 1.0, Nf.Ln), 0, 1);
uniform float nonspec = 0;
lightsource("__nonspecular", nonspec);
if (nonspec < 1) {
/* Primary specular */
Css = Cspec * (1-nonspec) * strandspecular( t1, Vf, Ln, exponent);
/* Secondary specular */
Css += Cspec2 * (1-nonspec) * specmask *
strandspecular( t2, Vf, Ln, exponent2);
return Cdd * mix( Cbase, Ctip, v) * (Ka*ambient() + Kd * Cdd ) +
Ks * Css;
I want to use this shader in Mantra... any possibility?
