shift img sequence
Ungoliant
hello people, i have one question, how can i shift a image sequence with the expression op:/img/comp1/Stand_blue Im working with COPS and importing to sops with the expression, im doing and army with sprites, but i wanna have some procedural variation from the sequences.
thanks for your time,
you can shift the sequence by adding/subtracting from the current frame. For example if I want to shift ahead 5 frames:
/myDir/myImgSequence.`padzero(4, $F + 5)`.exr
If your sequence has a frame padding such as $F4, then you need to use the padzero() expression.
