mwagner Posted July 14, 2003 Share Posted July 14, 2003 heya fellas, this is my 1st actual question on these forums and i've read some good stuff on here so far...i'm expecting good input i'm trying to recreate a pretty popular effect, the atomic bomb explosion! BOOM! now aside from the explosion itself, here is where i am having trouble thinking of how something like this would be done. the buildings....how do i get the buildings to really seem like they're being blasted by an intense force of air, as well as being blasted to bitty pieces? the effect won't focus on one building rather then a small city, so it wouldn't have to be immensly detailed on a small scale. as far as conceptualization on how to do this effect, the main problem i ran across is how to have buildings be effected in a radius as they would be by a central explosion? on a side note: i'm pretty sure i can get the billowing mushroom cloud effect by using i3d and metaballs, right? anyway...i'm not looking for a definite answer here, but any suggestions or fingers pointed towards helpful tutorials would be much appreciated. thanks guys and gals, i'll try to keep y'all updated on the progress...if any Quote Link to comment Share on other sites More sharing options...
anakin78z Posted July 14, 2003 Share Posted July 14, 2003 the main problem i ran across is how to have buildings be effected in a radius as they would be by a central explosion? You can probably set up a simple trigger system, where you place a point for each building, then compare the distance to the center of the explosion to the blast radius. If the radius is bigger than the distance, boom! I just watched T2 again, and I gotta say, their blast effect was pretty sweet. I'm guessing they did it mostly practical, but there was a certain simplicity to it that made it look really good. Not sure how to explain. Just go rent it or something -Jens Quote Link to comment Share on other sites More sharing options...
mwagner Posted July 14, 2003 Author Share Posted July 14, 2003 oh i own T2 i really do like the effect as well. thanks for pointing that out as an example. i heard the explosion in T3 was incredible as well so maybe i'll have to check that out. thanks for the suggestion. i'll see what i can come up with. -later, matt Quote Link to comment Share on other sites More sharing options...
jjstanley Posted July 14, 2003 Share Posted July 14, 2003 I've never done this but my first try would be to use the force from a rapidly expanding metaball and simple RBD. Like I said I've never tried it but can't see why it wouldn't work. Quote Link to comment Share on other sites More sharing options...
mwagner Posted July 16, 2003 Author Share Posted July 16, 2003 sorry, RBD? .......I AM THE UBERNEWB Quote Link to comment Share on other sites More sharing options...
mwagner Posted July 16, 2003 Author Share Posted July 16, 2003 sorry...Rigidbody....got it :-\ i haven't touched those yet. do you know of any good tutorials for the RBD system? Quote Link to comment Share on other sites More sharing options...
anakin78z Posted July 16, 2003 Share Posted July 16, 2003 Hmn... I don't think there's any good tutorials for it. Houdinis RBDs are a bit... unrefined. Some people swear by them, saying they rock, but there's a lot of setup involved, and you gotta find the right values. If you just start playing with them, you might get some bad results. Wow, I was no help whatsoever. Sorry, Jens Quote Link to comment Share on other sites More sharing options...
jjstanley Posted July 16, 2003 Share Posted July 16, 2003 I realized when I went to do an example that RBD has changed abit in Ver 6 but I made a similar file using particles. Hope this gives you some ideas. Bomb.zip Quote Link to comment Share on other sites More sharing options...
jjstanley Posted July 16, 2003 Share Posted July 16, 2003 Here is the only RBD tutorial I have come across. It is old but may help you. RBD_intro4.zip Quote Link to comment Share on other sites More sharing options...
mwagner Posted July 16, 2003 Author Share Posted July 16, 2003 awsome. i'm gunna check those out asap. much appreciated Quote Link to comment Share on other sites More sharing options...
