copy+bevel on edge=crash ?
hi there,
i ve a problem with a scene maybe someone can help me.
the problem is : my scene crash when i use a polybevel node in "edge mode" in a subnet before a copy sop.
i've no problem with the bevel point mode.
it looks strange because when i re-open the crashed file it's working and if i tweak any values after this it's crashing again.
If you have time to take a look on my scene the bevel sop is in the subnet1 in the platonic object.
the console return me this error : Fatal error: Segmentation Fault
thanks to take a look on this if you have time
system
xp64 on xeon cpu
16go
houdini apprentice 10.0.595
testcopy.hipnc
thanks for your attention and time.
If it can help, it's working when i put the bevel node between the 2 extrude node. The result is almost the same and it does'nt crash.
it can be link with the copy stamping too. when i keep the bevel node in the same position and disable the copy stamping it's working.
