Pyro uplift force
Macha
We can specify the buoyancy direction in the pyro smoke solver with a direction vector.
However, that direction is uniformly applied to every part of the pyro simulation.
Would it be possible to use a vector field, so that every point in space would have its own direction (so that we could make a radial boyancy force, or a noisy one).
I know we can do this with other forces, but boyancy is so much more effective than, for example, gravity.
I generally move my pyro sims (both combustion and smoke exclusive) with point velocity and vorticle strength. I found that modifying the buoyancy can have unrealistic results, since smoke inherently travels upwards when dissipating. Smoke is the keyword here. Other volumetric effects such as dust and dry ice behave differently, but I usually don't tweak the buoyancy too much when dealing with those either. Sorry that I couldn't provide some technical solution, it's mostly aesthetics I guess :rolleyes:
Edited by static
you can do that very easily
according to help:
"Given an ambient temperature Ta, temperature T, buoyancy lift l, and buoyancy direction of B, the force will be: ((l * (T-Ta)) * B "
so if you have your vector field then simple Gas Force VOP will do the whole job
just zero out pyro's buoyancy lift before to avoid double computation
I was attempting this with a vop force... but I'm unsure of how to grab the temperature with the op: expression. Can someone help? :)
I'm not sure this is what you were looking for Macha, but you could make B a vector value which would give you vector mutliplied by the magnitude and sign of the final temperature scaled by lift. I wasn't sure how that gas vop field works as it seems modifies a field like a volume vop in SOPs. I don't see how it can apply force.
macha.hipFetching info...
Hey Macha,
you can use a point cloud lookup in a GasFieldVop to update the velocity ( or anything else too )
All you need is a bunch of point with some velocity attributes in Sop level.
Have a look at the attachment :)
pyro_vel_force.hipFetching info...
  On 6/10/2010 at 7:44 AM, Macha said:
Here's an example of what I'm talking about:
I did it with a cheapo field force. I have never looked into making VOP forces, so thanks for that Jason, I'll look into it.
Cool, merci for the gasfield VOP.
The force vop is nice too because I can simply use point position as vector field if I want a radial force, but I find it very slow and don't know either how we can get at other fields, as Jason mentioned.
Gasfield seems fast.
The gasField Vop allows you to access any field. Inside, a field is just a parameter with a field name.
eg : to grab the temperature field, just lay down a parameter vop in a gasfield vop and call the parameter "temperature". And to set a field, same thing but set the "Export" to "Always".
That's what I did with "vel_in" and "vel_out" in "/obj/AutoDopNetwork/gasfieldvop1"
hope that helps ...
That's kind of true Chumbuk, but there is a hack to this.
You can force the recook on every frame by adding [$F] at the end of the OP command :)
like that op:/obj/my_field_force/out[$F]
pyro_vel_force2.hipFetching info...
I know, very obscure syntax ...
  On 6/10/2010 at 9:42 AM, chumbuk said:
point cloud with "op:" are limited non animated source SOP vector , you can use Gas pattikle to field DOP, it don't have this problem
Don't know about that, but I had a quick test with a constant vector in a vopforce: It's so painfully slow compared to the exact same thing in a gasfield vop ... I wouldn't waste any time with the vopforce if I were you :rolleyes:
  On 6/10/2010 at 10:42 AM, mightcouldb1 said:
So is there any work around for getting access to other fields in DOPs from upstream by the VOP force? I'd like to try and finish my example :)
ah, now I see what you meant :) - I thought it would somehow modify the path.
One for the docs.
