Creating velocity field
Farid
Hi
Can someone help me,i'm trying to create a velocity field from RBD object,because there are many object,i didn't understand how i can extract all this velocity ion one field,that i can then use in the sop level.
Thank you very much for your help.I attached the file,maybe someone can do this for me:_)
Thanks again
Best Regards
Farid
Velocity_Field.hipnc
use a dopimport and select your object :P
like this : Velocity_Field2.hipnc
Hi
Thanks again
Best Regards
Farid
I thought you wanted a velocity field, that's one B)
If you want to see the velocity vectors from points,
set the display to the dopimport node,
go to the display options ( D key ) and in Guides & Markers and display
"v" from Custom ...
Thanks a lot for the quick reply,but why i can't visualise the velocity?,i just see a volume,bear with me ,i'm realy confuse :_((
cheers
"v" from Custom ...
Thanks again,but i know this,the problem is that i want to use this field to drive particle,so to speak ,fetshing data from RBD in this case the vel,and try to use it at the sop level,i have to collect all this data (vel),store them in a field,then transfer the velocity attribute to the particle,what i see is just a volume,i tryed to extract the vel with a vop sop,using volume sampling,but i think this work only with a fluid ,Grrrrrrrrrrrrrrrrr
Thanks again for your effort!
Cheers
you could have said you wanted cheap sand simulation :P
That's a simple setup to transfer vel from dops to pops :
Velocity_Field3.hipnc
thanks,it's realy cheap :-))the behaviour is not real at all,because they don't tend to stick on eachother,you know miguel (i'm sure) told me i have to sample the velocity,and transfer this attribute into particle
i konw from fluid that i can sample the sdf,and transfer it via voppop,and it works well,now for simulated sphere,it looks like each one have it's own field,the particle,loose track when they live the boundary
if you look carfuly at his reel,the velocity field,is compensating all the sphere at once.
Thanks again
cheers
