Centroid - SOP
  • 5 weeks later...
First of all,
I just started learning HDK. So I am really beginner. And I do not have C++ knowledge yet......
This OTL sounds really nice and I wanna try!! more like I need to try!!
But I got difficulties how to compile this.
I am using Ubuntu10 X64.
I tried to compile this following "http://www.sidefx.com/docs/hdk10.0/hdk_intro_compiling.html"
But I tried to compile the SOP Star sample,
I get this
Making SOP_Star.o and /root/houdini10.0/dso/SOP_Star.so from SOP_Star.C
sh: g++: not found
And I got stuck here.... I could not even compile samples yet. embarrassing....
I installed csh by the way. Do I miss something?
I tried to find "how to do" on the internet but I could not find any for like me beginners.
If anybody even know some good web site to look at it, I would really appreciate it!!
Thanks
You'll need to install some of the more basic compilation programs/packages.
Try: apt-get install build-essential
build-essential is a shortcut for a bunch of the more common building tools.
Edited by graham
  • 2 weeks later...
I finally could succeed to compile in Linux. Thanks Graham!!
I also compiled with windows 64bit vista and It seems working fine in Houdini 11.
I used Visual studio 2005 off course.
But when I compile I got this warning (look at Jpg). Is this fine???
Also I was trying to use Makefile in windows,
I tried Cygwin and other stuff like nmake.exe ver 1.5(seems works only 32bit). But no success yet.
Is anyone can tell me how to use makefile in windows correctly??
Thanks
Hi efx,
that warning is okay, what it complains about is a macro that i'm using to check the timing of these operations, these macros get en/disabled by a
#define DEBUG
statment in the .h header file
In the next version, (that i'm hopefully finishing soon) i'll try to get rid of that warning.
Infernal
  • 2 years later...
after some time I've committed some changes into the repository,
--> changes for the H12.* GA modules
--> inheriting of attributes from the primitives onto the centroids
--> inheriting group names onto the centroids
http://gitorious.org/centroid-sop/centroid-sop
Seb
Edited by Infernalspawn
  • Like 2
  • 4 years later...
/opt/hfs16.0.751/toolkit/include/UT/UT_String.h:141:5: error: ‘UT_String::UT_String(const UT_StringRef&)’ is private
     UT_String(const UT_StringRef &);
SOP_Centroid.cpp:1119:49: error: within this context
   UT_String primAttrName = it.attrib()->getName();
In file included from /opt/hfs16.0.751/toolkit/include/UT/UT_Lock.h:27:0,
                 from /opt/hfs16.0.751/toolkit/include/UT/UT_ThreadedAlgorithm.h:28,
                 from SOP_Centroid.h:33,
                 from SOP_Centroid.cpp:26:
/opt/hfs16.0.751/toolkit/include/UT/UT_String.h: In static member function ‘static void SOP_Centroid::matchPrimAttribNameList(const GA_AttributeDict&, UT_String, UT_StringArray*)’:
SOP_Centroid.cpp:1139:45: error: within this context
   UT_String primName = it.attrib()->getName();
makefile:57: recipe for target 'SOP_Centroid.o' failed
