Hold $F
How can I hold the $F current value?
I want to create a attribute that when it evaluates True, holds the current frame number.
If I use $F it will change every frame. I tried the "lock" expression, but it change the frame value as well.
I am digging the expressions manual, but didn't find anything that may work.
Does anyone have an idea?
Thanks
Thanks
that's very abstract problem
maybe try to be more exact
but the easiest way would be probably Hold CHOP which can hold left input value when the trigger changes from 0 to 1
you must also evalutate condition one frame before current frame...
if condition was true one frame before and it is true now than you don't change your parameter/attribute
if condition was false one frame before and it is true now then you change your variable/attribure to $F...
you can use chf function for that
Edited by majikal
