MotionBlur Pass
I know that it is possible to render a motionblur pass by exporting a variable calculated by getblurP vex. However, I think this always requires the blur to be a Geometry Velocity Blur.
Is it possible to render a motionblur pass with the other motionblur method: By setting the Geo Time Samples on the samples tab of mantra render node.
The reason why I ask is because I have something going through a CHOP and the v attributes cause the occasional weird blurring effect. Appending a trail sop instead does not solve the problem. On the other hand, rendering blur with Geo Time Samples is fine except that I can't render a separate motionblur pass (I need it for compositing in Nuke).
Edited by Macha
I've never heard about this limitation. All kinds of mblur should produce output with getblurP(). Have you asked mantra to not actually blur the image (with "vm_imageblur" property)?
