unxetas Posted August 14, 2003 Share Posted August 14, 2003 hum... ok, I've followed the videos on creating those nifty clouds and I managed to create 1 perfect cloud... but.. now I need more than one I can't create different clouds on different objects because then houdini asks me for the SOP that contains the geometry to render the i3d file... If I create different clouds inside the same OBJ and then merge them together, the i3d texture doesn't work properly.. all I get is a veeery small little cloud, instead of the majestic clouds I had created :| I couldn't think of a way to create different textures for different clouds, unless I applied many Atmosphere objects.. Any suggestions on the most efective way to do this?... Thanks for all the help guys Tiago EDIT: btw, I'm creating the clouds by copying a metaball to an extruded and edited box.. this works great for just one cloud! Quote Link to comment Share on other sites More sharing options...
michael Posted August 14, 2003 Share Posted August 14, 2003 not sure but you might try instancing that cloud onto a grid or something....you can change things about each instance to get variations... Quote Link to comment Share on other sites More sharing options...
unxetas Posted August 14, 2003 Author Share Posted August 14, 2003 nop, can't get it to work.. my guess is the atmosphere sop doesn't generate "geometry". I tried changing the geometry parameter in the instancing options (render as bla bla bla, procedural, geometry as is, etc) but all I ever get is a black scene hehe.. If I render the atmosphere OBJ by itself, bang, perfect cloud... Quote Link to comment Share on other sites More sharing options...
AndrewVK Posted August 15, 2003 Share Posted August 15, 2003 >>I can't create different clouds on different objects because then houdini >>asks me for the SOP that contains the geometry to render the i3d file... You can See attachments (H6.1nc) It`s posible to use all this clouds within single Atmosphere object, however standart i3dFog shader must be modified cloudgen.zip Quote Link to comment Share on other sites More sharing options...
AndrewVK Posted August 15, 2003 Share Posted August 15, 2003 >>It`s posible to use all this clouds within single Atmosphere object, >>however standart i3dFog shader must be modified Oops. It`s imposible without z-sorted array...but arrays are not currently supported within VEX:( Quote Link to comment Share on other sites More sharing options...
NatXotic Posted August 15, 2003 Share Posted August 15, 2003 EDIT: sorry, this is unxetas forgot to log out on nat's computer err.. haven't checked the attachment yet but.. how would you go about modifying such a shader? Don't try to explain the modifications, I'm just curious on how to get to the shader... Anyway, I got it to work by using the metacloud instead of the fluffly.. but I still have to create all the "clouds" (metaballs copied to box's points..) inside one the same object and merge them together.. I had success before with duplicating the atmosphere object, but I can't find an handle to manipulate the fog object in the scene, and since you don't see the cloud unless you render, it's hard to manipulate it by changing the translation values.. Quote Link to comment Share on other sites More sharing options...
AndrewVK Posted August 15, 2003 Share Posted August 15, 2003 >>I'm just curious on how to get to the shader... Dont modify standart shaders itself! Tools -> Operator Type Manager -> Operator Type Libraries -> D:/HOUDINI/houdini/otls/OPlibShop.otl Find & select shader. Right Mouse Button -> Edit Contents Swich to VflCode tab & hit "Save as File" Open saved text...modify...rename...install as new shader:) Now You can tweak shader within SHOP: Load new shader -> RMB on shader -> Type Properties -> Vex Code tab >> I can't find an handle to manipulate the fog object in the scene, and >>since you don't see the cloud unless you render, >>it`s hard to manipulate it by changing the translation values.. You can create Iso Sop (3D texture mode) within Attmosphere Object Quote Link to comment Share on other sites More sharing options...
unxetas Posted August 15, 2003 Author Share Posted August 15, 2003 oh, nice Thanks for all the help! Gotta start playing with those shaders after I finish this project.. Quote Link to comment Share on other sites More sharing options...
