Sankar Kumar Posted January 11, 2011 Share Posted January 11, 2011 Hi, I am new to houdini, any one please explain me how to use metaball magnet force that used in Houdini 11 sneek. Can any one just give me the steps to do this effect. Thanks in Advance.. This is my First houdini Simulation Shatter HD_New.mov Quote Link to comment Share on other sites More sharing options...
Stromberg Posted January 11, 2011 Share Posted January 11, 2011 I would also like to hear abit more about this, i got it working once using the shelf tools, but after that it hasnt worked anymore. Quote Link to comment Share on other sites More sharing options...
Stromberg Posted January 11, 2011 Share Posted January 11, 2011 Actualy i found something on the forum, where i learned quite a bit on what went wrong in my case Take a look at the .hip file there. Thanks to Macha for creating the file Quote Link to comment Share on other sites More sharing options...
Sankar Kumar Posted January 12, 2011 Author Share Posted January 12, 2011 Any one explain how to destruct a RBD object using metaballs... Quote Link to comment Share on other sites More sharing options...
Stromberg Posted January 12, 2011 Share Posted January 12, 2011 -.- Quote Link to comment Share on other sites More sharing options...
Omy Posted January 24, 2011 Share Posted January 24, 2011 Any one explain how to destruct a RBD object using metaballs... all you need to do to destroy a building is to fracture the geometry.Having said that,you can fracture the geometry at SOP level by yourself or by using any shelf tool.so now u got it fractured nextly,you need to animate the metaball. DOPs you need to use rbd fractures,magnetforce,metaball and sopgeo. I think now you got what you wanted.I faced some problems using metaball thing worked out in H 11.I dont know whether i did resolve or not.But this is how its done. Happy houdining! Quote Link to comment Share on other sites More sharing options...
anim Posted January 24, 2011 Share Posted January 24, 2011 no need for pre-fracturing in SOPs just use auto fracturing in H11, check to use magnet forces for fracturing, add magnet force and you are done, here is example metaball_fracture.hip 1 Quote Link to comment Share on other sites More sharing options...
Sankar Kumar Posted January 25, 2011 Author Share Posted January 25, 2011 Thanks a lots for the help.. My problem is the magnet force strength and the size or meta balls. Quote Link to comment Share on other sites More sharing options...
