chrisperry05 Posted January 22, 2011 Share Posted January 22, 2011 Hi, I have a really simple smoke simulation which i've advected some particles to. The problem is at random times during the render it will just crash? I tried a bit of sorting through and have narrowed it down to the advect pop that is causing it. If i turn off the particles and render the smoke it is fine? This is the first time i've tried using advection and i'm unsure if i've done something wrong which is causing the crash, any help would be really great. I've attached the .hip Thanks Chris Quote Link to comment Share on other sites More sharing options...
mawi Posted January 22, 2011 Share Posted January 22, 2011 Hi, I have a really simple smoke simulation which i've advected some particles to. The problem is at random times during the render it will just crash? I tried a bit of sorting through and have narrowed it down to the advect pop that is causing it. If i turn off the particles and render the smoke it is fine? This is the first time i've tried using advection and i'm unsure if i've done something wrong which is causing the crash, any help would be really great. I've attached the .hip Thanks Chris What H version are you using and does it say anything upon crash?. I had some problems rendering volumes and particles in 11.0.504. If I remember correct mantra errored out with "exit code 11". Update to latest build solved it. Quote Link to comment Share on other sites More sharing options...
chrisperry05 Posted January 22, 2011 Author Share Posted January 22, 2011 Hi, Thanks for the reply. I actually just managed to solve it, i changed the advection to "No threading" and it rendered through fine. I'm a bit of a noob so if anyone could explain to me why this was, would it be a RAM issue? Thanks again. Quote Link to comment Share on other sites More sharing options...
sam.h Posted February 7, 2011 Share Posted February 7, 2011 This is a bug, I have a ticket in with SESI (id 36700). The solution is to do exactly what you did Quote Link to comment Share on other sites More sharing options...
SpencerL Posted February 7, 2011 Share Posted February 7, 2011 Are you writing out your particles as a .bgeo sequence before rendering? Always best to write out sims, especially if you are rendering. Quote Link to comment Share on other sites More sharing options...
