yongbin Posted January 28, 2011 Share Posted January 28, 2011 what is equvalent to houdini's attribute transfer sop, in maya? is there a mel command? or a node? help me. thank you! Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted January 28, 2011 Share Posted January 28, 2011 (edited) Hmmm, I don't think there is an equivalent since Maya doesn't use the concept of points and vertices, they just have vertices which don't have attributes (like color).That doesn't mean there isn't a way, there just isn't a simple way. You might have better luck asking Autodesk directly if you have current support or at least a Maya specific forum. Edited January 28, 2011 by lukeiamyourfather Quote Link to comment Share on other sites More sharing options...
Solitude Posted January 28, 2011 Share Posted January 28, 2011 Hmmm, I don't think there is an equivalent since Maya doesn't use the concept of points and vertices, they just have vertices which don't have attributes (like color).That doesn't mean there isn't a way, there just isn't a simple way. You might have better luck asking Autodesk directly if you have current support or at least a Maya specific forum. http://www.soup-dev.com/examples.html << Great set of plugins for maya, one of which is attribute transfer Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted January 28, 2011 Share Posted January 28, 2011 http://www.soup-dev.com/examples.html << Great set of plugins for maya, one of which is attribute transfer Nice! I stand corrected. Quote Link to comment Share on other sites More sharing options...
yongbin Posted January 28, 2011 Author Share Posted January 28, 2011 Wow, thank you guys for advise! Quote Link to comment Share on other sites More sharing options...
spev Posted January 28, 2011 Share Posted January 28, 2011 you could always try the transfer attributes tool under the polygon/mesh menu as this will transfer per vertex colors , uv's and point positions between geometries (or same geo.) it is a little slow but I have managed to get houdini like interactions out of it...i.e simple collision detections etc.... Quote Link to comment Share on other sites More sharing options...
