hopbin9 Posted February 3, 2011 Share Posted February 3, 2011 Hi, I'm working on animating a COP network to be used as a texture and I can render it to a file sequence, but it would be cool if I could just reference the COP inside a VEX shader directly. I've seen things with Node references in Houdini, where you can go opdef:/Shop/thingy?filename and it can reference something in an asset or OTL. It would be cool, if you could go something like "chop:/mycomp/null" in the "texture map" field of a SHOP/VEX Decal, then the shader would render using a texture generated by the COP directly. Saving me the trouble having to use an image file. Is something like this possible? Quote Link to comment Share on other sites More sharing options...
malexander Posted February 3, 2011 Share Posted February 3, 2011 Yes this does work, as long as it's done in a material or SHOP node, and not in a VOP. Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted February 3, 2011 Author Share Posted February 3, 2011 Cool, so I have use to properties then to pass it to the VOP level. What is the syntax for referencing the COP output? Quote Link to comment Share on other sites More sharing options...
Macha Posted February 3, 2011 Share Posted February 3, 2011 Like this? Be careful though. I've done that before and had some problems with updating. Quote Link to comment Share on other sites More sharing options...
Macha Posted February 3, 2011 Share Posted February 3, 2011 forgot file... coptex.hipnc 1 Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted February 3, 2011 Author Share Posted February 3, 2011 thank you! That's awesome. I got it working. This is going to save me a ton of time Thanks guys! Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted February 18, 2011 Author Share Posted February 18, 2011 Like this? Be careful though. I've done that before and had some problems with updating. OMG! I think I now know what you were referring too. I'm having a very difficult time trying to get the COP reference to update. The COP is loading an image sequence, and then doing some effects on it. I'm then referencing it as a texture for some instanced nodes. My problem is that it's only rendering one frame from the COP! In the COP is a file node that reads in an image sequence like "image.$F4.png". When I render an image in Houdini it renders the current frame, but when I render on the farm all the render machines render only 1 image from the COP. As each frame is rendered they are all stuck on the same "image.0001.png" file (even if they are rendering different frames). Nothing I've done has been able to fix this problem. Anyone have some ideas for me? Thanks, Quote Link to comment Share on other sites More sharing options...
Macha Posted February 18, 2011 Share Posted February 18, 2011 (edited) Uhm....do you refer to it with an expression containing op: ? If so, try to add [$F] to it, and see if that helps. For example: op:/img/comp1/OUT[$F] Edited February 18, 2011 by Macha 2 Quote Link to comment Share on other sites More sharing options...
evgen Posted February 18, 2011 Share Posted February 18, 2011 Same problem with COP. I tryed to set start frame in geometry node to $F but doesnt helps Maybe we should put somwhere in houdini network script which will render COP/out node every time when network is cooking Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted February 18, 2011 Author Share Posted February 18, 2011 I tried adding $F as a parameter to the COP nodes, but didn't help. Thanks for the tip @macha, I'll give that I try. I ended up giving up on it, and saving out all the textures to images. So it's rendering correctly now. Maybe that's better approach anyway, since I often have to render a scene multiple times to get it right and the COP network isn't modified anyway. Quote Link to comment Share on other sites More sharing options...
Benyee Posted September 28, 2011 Share Posted September 28, 2011 But how to fetch point color info as animation texture sequence for cop or write out to disk? Quote Link to comment Share on other sites More sharing options...
