Different material on an instance
hopbin9
How can I apply a different material on an instance of an object. The manual talks about overriding properties, but doesn't seem to give an example.
I have two materials in my SHOP. Both objects are rendering with the first assigned to the source object. The instance, I can't seem to figure out how to apply the other material.
Thanks,
As always in Houdini is all about wrangling attributes. See example for varying materials per instance. As Luke mentioned quite often you want to apply one material for all instances and vary only attributes of that. I's usually more efficient approach, then sending a number of materials to ifd file.
hth,
skk.
instance_mat.hipnc.zipFetching info...
Edited by SYmek
I have to do both cases actually.
The object is a television set, and there are many sets each showing a different texture file, but there are two different colored styles of TVs. They are all the same geometry.
So I'm instancing them but they all have the same image and are the same color.
Thanks for the example file. I think I get how you did it, but will this only work with point instancing?
